TwinTurbo.NET: Nissan 300ZX forum - Re: HELP!...my z misses horribly and I'm stumped
Mike87T
on August 07, 2008 at 9:42 AM
posted by DanoZ
on August 06, 2008 at 08:23 PM
Disconnect every connector at the PTU and CAS and clean and apply dielectric grease. This SHOULD fix it. If not, the intermittent dropping of that cylinder is probably the injector failing, then it totally failed.
DanoZ
20:23:24 08/06/08
Did you check out the PTU / search about it?
Drk93TT
20:55:16 08/06/08
Check the PTU for sure I had the same issue last week and
5280Z_nightstalker
21:53:15 08/06/08
Re: Check the PTU for sure I had the same issue last week an
DanoZ
22:07:21 08/06/08
It was one for the PTU but can you fill out your profile for
5280Z_nightstalker
22:54:57 08/06/08
Thanks alot, ill update my profile and take your advice (n/m)
DanoZ
00:13:12 08/07/08
Re: Did you check out the PTU / search about it?
DanoZ
22:03:59 08/06/08
Re: Re: Did you check out the PTU / search about it?
ZUL8TR
04:47:21 08/07/08
Other items to check that can also do that:
Audioquest
08:58:46 08/07/08
Re: HELP!...my z misses horribly and I'm stumped -
Mike87T
09:42:17 08/07/08
